| | | Forums66 Topics128,105 Posts1,056,209 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | '59 Chevy 1/2 ton with deluxe heater. (235) Trying to do the final button up stuff to hear the motor run for the first time. Noticed heater core has two different size taps. Does it matter which one goes where on the water pump?
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't think they're originally different sizes, but it does matter - see the installation setup in the accessory manual here, 3rd page in Bill | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | I don't see anywhere on that page that refer to hose routing. I'm sure my truck is set up as it always has been. Inner tap for the heater core is 5/8 and the outer one is 3/4. But, tap on the water pump and thermostat housing are for 3/4 hose. I did install an earlier heater control valve. Since they are easier to ffindfrom the parts suppliers.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Ahhh page 3. Thanks man found it.
