| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I'd like to start doing some body repair. What is the gauge of sheet metal used of the ad trucks. Is there any variation between different panels or are they all the same? Thanks | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 |
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As Bo posted, depending on how it was formed, it will fluctuate between 18-19 ga., some thinner some thicker. People get fooled into thinking that it is heavier because of the compound curves, think egg shells. DG
Denny G Sandwich, IL
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | My F7 measures out at 19 ga on the hood, 17 ga on the front fenders. So you may see some variance, some likely caused by the forming process used at the factory. Some of the structural members (floor brace, running board brackets, etc) may be a thicker metal, 16 or 14 ga. But for most of your repairs, 18 ga cold rolled steel will take care of it. | | |
