0 members (),
389
8
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | Hi- Finally took my desert rescue pick-up for a ride after getting basic mechanicals going. She's weaving all over road when I get up to 30mph. Has brand new tires. What is most likely culpit? Will Front End Alignment help or is this likely a steering box problem? Or front end parts? Just wondering what others have found... Ron A | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, Ron,
Welcome to Stovebolt.com.
I'd be pleased to stop by to meet you and your truck: 732-7989
You have already ID'd the possible problem(s): - front end alignment (toe-in/out is easy to determine and adjust) - steering gear needs adjustment (easy to determine and adjust) - front end parts are loose/worn-out (easy to determine and relatively easy to replace) - tires over-inflated - raise and lower the PSI by trial-and-error
| | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Welcome to the Affliction.  Could be one of very many things including alignment: Tie-rod ends, draglink ends, kingpins, spring pin bushings, wheel bearings... I don't know what you have done so far, but I suggest you jack up the front end and put stands under the frame so you can inspect, shake, and wiggle everything to see where the loose-ness is. Do you have a shop manual? If not, get one. Some are reprinted on the net. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0301.htm Repair parts are available to completely rebuild your front axle and steering, some of them from NAPA and other local auto parts stores. Good luck.
Professional Novice
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 1st thing to do is have someone work the steering wheel back and forth in its free play while you watch what moves below, that'll give you a good idea what to start checking .... and take Tim up on a visit, 2 heads are always better  Bill | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | bias ply or radial?
Bias ply are notorious for wander.... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Radials will wander, too, if they are over-inflated.
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | While you are going over the front end, also consider that a loose rear end will cause wander that may seem to come from the front end. Loose spring pack- busted spring(s)- bad spring mount bushings- bad spring mount shackles.
The most likely problem is EVERYTHING has been neglected and will need attention.
The nice thing is it's all fairly simple and when it's done will make the truck a real joy to drive. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | . . . The most likely problem is EVERYTHING has been neglected and will need attention.
The nice thing is it's all fairly simple and when it's done will make the truck a real joy to drive. Truer words were never posted. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Radials will wander, too, if they are over-inflated. They'll also wander if they're mounted on too narrow of a wheel for the width of the tire.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My bias wander but mainly if I get into a groove or rut in the road. Otherwise they are great. Two fingers on the steering wheel at 50 mph on a smooth road. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I would first suspect King Pins. Its what everyone doesn't want it to be, so they fix everything else first. Chances are you have 60 year old worn out king pins. I hope I am wrong, but its not THAT hard to replace them. Good luck!
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | The answer to your question is very likely: Every part that moves, front and rear. If all of the moving parts aren't worn out, they are out of adjustment. It is now time for you to become intimately familiar with the entire steering and suspension systems. It is way more fun than body work! Carl
| | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | when I would hit the smallest dip in road my 51 would swerve all over the place. replaced front leafs now she stays straight even when I hit big dips. | | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | Thanks for all your reponses. Very helpful. I adjusted steering and it is much improved. Also, I've been driving a Camry or similar for 20 yrs; I forget that these older worm gear vehicles are a little more work to steer. Right? Ron A | | |
