0 members (), 90 guests, and 1 robot.
Topics128,055
Posts1,055,782
#104776 04/14/2002 8:33 PM
Junior Member
Junior Member
Has anyone done the conversion to a 5 window cab by cutting out the corner and welding in a window recess, instead of replacing the intire top of the cab?
#104777 04/15/2002 1:55 AM
I have not done one but I met a guy about 2 years ago that had done it. I think he had cut it about 4" all the way around and fit and welded in cab .Wish I was more help,I have been considering it myself. smile
#104778 04/15/2002 6:05 AM
It would be FAR easier to take the whole top off at the seam and cut through the front posts, PERIOD.
Funny thing is, I am planning on doing just the opposite! smile
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#104779 04/15/2002 6:35 AM
Here's a shot from Metalman's shop of a three to five window conversion:
Five Window Donor Cab
#104780 04/15/2002 3:43 PM
I did just that on my '51. The method was dictated by the fact that my 5-window donor cab was almost a total rust-out, except the area around the corner windows. I am talking major swiss cheese here, on the roof and around beltline. It may well be easier to chop out the entire roof, but that was not an option for me. The plan I followed was to cut the windows out of the deluxe cab, then trim the outer sheet metal down to the minimum required for a good fit in the 3 window cab. The inner sheet metal was cut on existing seams only (where possible). It was actually more like removal of spot welds. So you have the donor windows out to use for a pattern before ever touching the 3-window cab. Carefully cut the 3-window cab and use the new pieces as 'plugs'. If you do this carefully, using the existing cab seams (they are in the same place on both cabs) as reference points, then you will get perfect alignment. I used a combination of a sawzall and cutoff wheel, a plasma cutter would be nice but is not required.
The new corner window sheet metal is then butt-welded to the old. Bodywork should be minimal and mostly in the roof area where there is a slight compund curve. Grind off excess weld and use body filler to finish it off. If done right you wont need much.
A bonus of doing it this way is that with the inner sheet metal removed, you have access to the pillar post and can easily weld in a reinforcement tab for shoulder belts. I will post some pictures of how it turned out if anyone is interested.
#104781 04/15/2002 10:48 PM
Junior Member
Junior Member
Maybe someome should make a replacment panel for the inside and a window frames to be fitted welded into cutouts on the corners for windows. It would seem that adding corner windows would easier this way than replacing a complete cab.
