3 members (Leo, treegrower, Eisenholtz), 103 guests, and 2 robots.
Topics128,140
Posts1,056,774
Members48,454
I'd like to change to an auto maybe a GM 200 overdrive.
Do I need to modify the floor for the tranny?
Honestly, I never owned a burb, but I can tell you the floor doesn't need to be modified in a 1/2 - 3/4 ton pickup. And since the drive line in those would be the same as yours, adapting a GM200 should not be a problem. Where are you getting your tranny adapter? just curious as there are more available than years ago.
Drew
I'm not familiar with the term GM200, but if you are referring to a TH200-4R you will need to modify the floorboard.
TH200-4R in a '54 GMC.
