| | | Forums66 Topics128,149 Posts1,056,814 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | I'd like to change to an auto maybe a GM 200 overdrive.
Do I need to modify the floor for the tranny?
Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Honestly, I never owned a burb, but I can tell you the floor doesn't need to be modified in a 1/2 - 3/4 ton pickup. And since the drive line in those would be the same as yours, adapting a GM200 should not be a problem. Where are you getting your tranny adapter? just curious as there are more available than years ago.
Drew
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm not familiar with the term GM200, but if you are referring to a TH200-4R you will need to modify the floorboard. TH200-4R in a '54 GMC. | | |
