6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, Gdads51), 183 guests, and 6 robots.
Topics128,264
Posts1,058,358
Members48,485
#1047478 08/06/2014 5:34 PM
Can anyone tell me how to convert an old 58 Mack from positive ground to negative ground? Thank you, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
What voltage? Are you running a generator or an alternator? The starter doesn't care what polarity it gets but a DC generator needs to be re-polarized to negative ground. it will probably be necessary to obtain a negative ground voltage regulator, since there are some internal wiring differences. The simplest approach will be to retrofit to a negative ground alternator if possible.
Does the truck have a series-parallel switch for starting on 24 volts? If so, that switch will probably have to be replaced with one for negative ground polarity.
Scott,
If you are keeping the voltage the same, what is your reason for reversing the polarity?
I have to convert it because all of my trailers are wired for neg. ground. Also, electric brake box will not work with pos. ground.
