11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith), 78 guests, and 2 robots.
Topics128,032
Posts1,055,523
Members48,425
#1045537 07/29/2014 2:52 AM
hi guys,
i bought some new knobs for the side and front vent but its not clear to me how they fit.
do they glue on? they have a cross shaped slot at the back, one slot having parallel sides the other tapered.
if i push the knob on the arm with the arm located in the parallel slot its too lose and if i use the tapered slot it wont go on.
confused (yet again)
49 1/2 ton
what am i missing?
Ex Hall Monitor
Ex Hall Monitor
I've not dealt with a '49 but if it's the same as my '38 factory knobs are cast on. The wire shaft is permanently bonded inside the knob. Replacements are left to the installers discretion as to how they are bonded. If this is the case with the '49 the slots are simply the manufacturer's way of giving the installer options. Having said all that it's possible the '49 is nothing like the '38 and everything I just said doesn't apply. Hopefully for both of us someone with '49 experience will chime in. Good luck with it.
Yes, the repop knobs wont stay on without some kind of help. I used electrical tape to snug up the fit good enough that it works if I don't really pull on it when operating the vent. Gluing it on would be a good option, but make it harder to replace later.
A dab of five minute epoxy. The original one lasted 65 years,
so yours shouldn't have to come off till the great grandkids
restore it next time round. Even then, they can just cut the
knob off and clean up the lever with a file.
DG
Denny G
Sandwich, IL
Yep, I used two part epoxy to hold mine on. If I need to remove it I'll just cut it off. It lasted about 67 years the first time, the epoxy should hold it for a while. Mine had a small metal clip that tightened the knob onto the arm, but it was worn out and as far as I know they're not reproduced.
My 46 GMC on Photobucket
All true. But, I doubt re-pop anything will last as long as the originals. Time will tell, but the knob will probably last due to lack of exposure to direct sunlight.
The new ones are most likely made from urethane, which actually
should hold up better than the original ones, which were
cellulose acetate, which doesn't hold up to time.
Any way you look at it, they are now doubt gonna out last all of
us, if they don't fall off.
DG
Denny G
Sandwich, IL
Thanks guys for the input.
Ive decided Im going to hold them on with a grub screw (after drilling and fitting a helicoil in the knobs)
Moderated by  ndkid275, Phak1
