| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i have another question,,i have 1966 cheverlet pickup,which has a v8 eng.the PO says it is a 327 ci. the eng has double hump heads.now to my question.would this be standard in a 1966.thanks again | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the "standard" engine in '66 was the 250, the 327 was one of the possible options .... get the number off the pad at the front of the pass side head to ID what it is
Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I don't believe that they ever used the double hump heads on a pick-up. As Bill suggests get the numbers off the front of the block and then you'll have an idea what you have. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | bill&don there is two groups of number on the machined sur face.12w126865&vo8130md.i do,nt have any idea what they are.all help is appricated. | | |
