7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#1047295 08/05/2014 11:38 PM
Just curious. Has anyone actually come across the bumper plug bolt for the center hole in both the front and rear bumper as per assembly manual. Like many, I just used another stovebolt.
Drew
Yes: it is an unthreaded bumper "bolt" and a spring nut (as I dimly recall). I'll see if I have one or a photo of one.
F Online: Content
Here is an original that I am using on my back bumper in the center hole.
http://s160.photobucket.com/user/st...novsky/DSCI0708.jpg.html?sort=2&o=50
Was not aware that the front bumper called for the same thing.
Cool. First time I've actually seen one. I think the front bumper only uses it if there is no addition of the apron which would require an actual threaded bumper bolt.
Drew
I think you might still use that same "plug-bumper-bolt" on the:
- 47-53 front bumper with this front splash apron (that has a tab with hole in the middle of the apron)
or
- as a filler on the 54/55st front bumper with this front splash apron (that has no tab in the middle of the apron)
or
- as a filler on any 47-55st front bumper that is installed with no front splash apron.
Why did they put a hole in the center of the rear bumper in the first place?
likely it's provision for mounting some design of optional grill guard
Not in 1954 (I do not know about earlier years, that used the same front bumper). In 1954/55st the 1/2 ton and 3/4 ton bumpers are the same. The GM accessory grill guard does not use that hole.
Jim Carter's site has some thoughts on this topic.
http://www.oldchevytrucks.com/blog/index.php/2010/02/lost-bumper-bolt/
Geez. Learning all kinds of cool info from a simplistic question. Ain't Stovebolt great ?
Drew
Thanks, Peter,
JC refers to the "center hole at the front held a vertical steel bracket which was needed if the truck was hand cranked".
One of the used Advance-Design bumpers that I bought came with that bracket - it was held on with a standard bumper bolt. I do not know if that bracket was standard-equipment from 47-53, when a bumper bolt was used in the center of the bumper to attach the front splash apron. It was of no use in 1954, when the harmonic balancer no longer had the "nubs" in the front for a hand crank.
I have only found that stud and speed nut on one used A-D bumper. It should be noted that from 47-55st the front bumper was used as the panel-body trucks' rear bumper, and that plug/nut might have been needed/used in those years?
Does anyone know the GM part numbers for that vertical steel bracket and the one inch long stud and the sheet metal speed nut?
Jim Carter carries the center non-threaded bumper bolt as a part of their complete set. The dome shaped head doesn't match the other bolt heads though which are also chrome plated rather than having stainless steel caps. center bolt
Tim, as you maybe know, any parts illustration I have, car or truck, that points out the bumper plug just sends you to 7.874 parts sheet number which list everything as a bolt across 1936 to 1951 years. So I'm at a loss to find that particular number.
I see no illustration for the bracket.
Drew
