| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi guys, i bought some new knobs for the side and front vent but its not clear to me how they fit.
do they glue on? they have a cross shaped slot at the back, one slot having parallel sides the other tapered.
if i push the knob on the arm with the arm located in the parallel slot its too lose and if i use the tapered slot it wont go on.
confused (yet again)
49 1/2 ton
what am i missing?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've not dealt with a '49 but if it's the same as my '38 factory knobs are cast on. The wire shaft is permanently bonded inside the knob. Replacements are left to the installers discretion as to how they are bonded. If this is the case with the '49 the slots are simply the manufacturer's way of giving the installer options. Having said all that it's possible the '49 is nothing like the '38 and everything I just said doesn't apply. Hopefully for both of us someone with '49 experience will chime in. Good luck with it.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yes, the repop knobs wont stay on without some kind of help. I used electrical tape to snug up the fit good enough that it works if I don't really pull on it when operating the vent. Gluing it on would be a good option, but make it harder to replace later. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A dab of five minute epoxy. The original one lasted 65 years, so yours shouldn't have to come off till the great grandkids restore it next time round. Even then, they can just cut the knob off and clean up the lever with a file. DG
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yep, I used two part epoxy to hold mine on. If I need to remove it I'll just cut it off. It lasted about 67 years the first time, the epoxy should hold it for a while. Mine had a small metal clip that tightened the knob onto the arm, but it was worn out and as far as I know they're not reproduced. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | All true. But, I doubt re-pop anything will last as long as the originals. Time will tell, but the knob will probably last due to lack of exposure to direct sunlight. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The new ones are most likely made from urethane, which actually should hold up better than the original ones, which were cellulose acetate, which doesn't hold up to time. Any way you look at it, they are now doubt gonna out last all of us, if they don't fall off.
DG
| | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | Thanks guys for the input.
Ive decided Im going to hold them on with a grub screw (after drilling and fitting a helicoil in the knobs) | | |
