| | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Truck didn't have the vent knobs or cable running to the side vents. Where do the vent knobs install and how do you run the cables (behind the dash I presume?
1955 GMC 100 Series 2
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the knob ends of the cables mount under the center of the dash, should be holes there, 2 for each knob mount flange .... the cables run straight back to the 'dash mat' and then to each side, where you should find holes just big enough for the cable to go in the kick area by the vents
Bill | | |
