Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (46 Texaco, Shade Baby, FAST55, Pete O), 145 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
#1047125 08/05/2014 5:14 AM
I've been putting my truck together. Bolted cab to cram bed is on and rear fenders. The front ones.... The inner fenders where do they bolt onto? I know front and an dinners go together obviously but where the inner fenders bolt onto??!
depends on the year wink usually you can bolt the entire front clip together off the frame [loosely] than set it on, and it should be fairly obvious how the pieces bolt on
On ADs the inner fenders bolt to the cab cowl and radiator frame. I would bolt the inners on first than the fenders rather than bolt the front clip together separately only because alignment issues will arise after a cab is taken apart. Others will have info to offer too. Don't forget any anti-squeak material that needs to be added as assembly occurs.
Drew
On the right side, they bolt to the toe board. The bolts come through the toe board from the inside and thread into the captive nuts on the rear of the inner fender. On the left side, they bolt through the rear of the inner fender into the captive nuts on the parking brake bracket.
Carl
Thanks, Carl. I wasn't very clear on my statement.
Drew
ahhh ok gentlemen thanks for your replies, going to start this weekend hopefully. Let me say one thing, ive never worked on a truck before, or anything for that matter. Just bought my first tool set, put the bed and rear fenders on. what ive learned, nothing is easy, bolts breaking off, rust everywhere etc. Thanks again.
Originally Posted by DADS50
what a beautiful blue,,, is that like a matte color?
Thank you
No matte in those pics
Tiddlar, One thing I do often with body panels is use longer than required bolts in just a couple of mounting spots. It helps me to get panels aligned. Then I use the required size on the remaining bolt holes and replace any longer bolts with those too.
Just a thought.
Drew
Can you bolt the entire front clip together off the frame on a 46 1/2 ton also what is anti-squeak
Drew, thats a good idea and one i will use when i put my 52's front end back on.
Joe
