1 members (Gib70), 85 guests, and 2 robots.
Topics128,094
Posts1,056,464
Members48,443
The last time I had to do this it was in a 283. Easy stuff.Just put a socket on the pivoting nut and turn it while listening to the motor. But a 235? I have to get the screwdriver into the slot of that stud that is moving up and down,back off the adjusting nut and then turn the screw ,all the time with the tools and my hands moving up and down with the cam action. There has to be another way to do this. Is there? What is the trick? Gratefully I only had a minor adjustment to make. I can't imagine having to do this twelve times.---Jack
Start the engine, get it hot 30 minutes running, Turn it off and adjust the valves.
Tommy
59 apache 1/2t
261 short stepside
Running adjustment of hydraulic lifters is not a good idea, since the lifter is getting slapped by the cam lobe several times a second. Warm the engine up for several minutes, then stop it and follow the firing order like adjusting solid lifters. From top dead center on the compression stroke, loosen the adjustment to allow the lifter to top out completely and tighten the adjusting screw anywhere from 3/4 to 2 turns, depending on whose advice you're following. One turn past the "zero clearance" point works well for me on stovebolt hydraulics. There's also a sneaky trick about putting a shallow groove in the ball end of the pushrod to allow trapped air in the lifter to escape that's outlined in a tech tip.
Did the groove for air release and it worked slick.---Jack
