3 members (klhansen, carbking, 1 invisible),
252
Mod | | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | I've been putting my truck together. Bolted cab to cram bed is on and rear fenders. The front ones.... The inner fenders where do they bolt onto? I know front and an dinners go together obviously but where the inner fenders bolt onto??! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depends on the year  usually you can bolt the entire front clip together off the frame [loosely] than set it on, and it should be fairly obvious how the pieces bolt on Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | On ADs the inner fenders bolt to the cab cowl and radiator frame. I would bolt the inners on first than the fenders rather than bolt the front clip together separately only because alignment issues will arise after a cab is taken apart. Others will have info to offer too. Don't forget any anti-squeak material that needs to be added as assembly occurs.
Drew
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | On the right side, they bolt to the toe board. The bolts come through the toe board from the inside and thread into the captive nuts on the rear of the inner fender. On the left side, they bolt through the rear of the inner fender into the captive nuts on the parking brake bracket. Carl
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks, Carl. I wasn't very clear on my statement.
Drew
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | ahhh ok gentlemen thanks for your replies, going to start this weekend hopefully. Let me say one thing, ive never worked on a truck before, or anything for that matter. Just bought my first tool set, put the bed and rear fenders on. what ive learned, nothing is easy, bolts breaking off, rust everywhere etc. Thanks again. | | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | what a beautiful blue,,, is that like a matte color? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thank you
No matte in those pics
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Tiddlar, One thing I do often with body panels is use longer than required bolts in just a couple of mounting spots. It helps me to get panels aligned. Then I use the required size on the remaining bolt holes and replace any longer bolts with those too. Just a thought.
Drew
| | | | | Joined: Oct 2012 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 42 | Can you bolt the entire front clip together off the frame on a 46 1/2 ton also what is anti-squeak | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Drew, thats a good idea and one i will use when i put my 52's front end back on.
Joe | | |
