9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#1046989 08/04/2014 6:39 PM
Just received word from Micron re: the head on my '54 235- He's got it cleaned up and magnafluxed- one crack- not too bad - he will get that repaired-head was .005 out of plane ( flat) so he'll get that flat again- along with valve job to include new vales and springs- just thought I'd post the progress on this part of the build. Mike will forward pictures of the repair as it goes and I'll post them here-
http://i1078.photobucket.com/albums...A-4DC3-89B5-5EB6CBAFDEC5_zpsyjwdiqic.jpg
http://i1078.photobucket.com/albums...A-4617-9758-2FC6DC174F96_zpspd6fixml.jpg
http://i1078.photobucket.com/albums...4-4EB1-B1B9-B3E3154F33EA_zpseczgviy6.jpg
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
SLAWNSKI #1046991 08/04/2014 6:40 PM
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
SLAWNSKI #1046994 08/04/2014 6:52 PM
http://i1078.photobucket.com/albums...5-48D8-8E93-BD33BD146FD7_zpsuhqcrmng.jpg
Valve stem on 2 exhaust was sticking pretty badly for me- the stem was pretty gummed up Mike said it took a bit to get them all out of their guides- All were gummed up to some degree- two cracked guides that will be replaced as well.
Looking forward to a fresh start
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
SLAWNSKI #1047014 08/04/2014 8:27 PM
Which cylinder had the crack in the head on it?? How do they fix the crack? Weld it or pin it??
SLAWNSKI #1047025 08/04/2014 9:22 PM
That looks like a pretty substantial crack to me. If it were mine, I would be looking for another head.
1951 1 Ton Completed
SLAWNSKI #1047028 08/04/2014 9:28 PM
The machinist said it was worth repairing- I'm taking his word on this- he's the one doing the repairs- if it was too bad he would have told me to scrap it. The rest of the head was in better shape- I was surprised I didn't actually see that crack when I looked over the head before I brought it in. That crack is at #2
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
SLAWNSKI #1047096 08/05/2014 3:25 AM
I hear so many talk about all of the cracked heads. Do all cracks leak? Are the cracks caused by catastrophic over-heating right before the truck was parked for good?
SLAWNSKI #1047119 08/05/2014 4:27 AM
H Online: Content
Stovebolt heads just have a nasty habit of cracking. Heads that were once considered to be junk get repaired now because the supply of good heads at the salvage yards has almost dried up.
SLAWNSKI #1047210 08/05/2014 6:08 PM
If your guy is doing the repair himself, you should be all set. It gets a little murky when they send it out and someone else does the repair. There is no doubt that it can be repaired by the right person. Personally I was burned once on a crack repair and the memory will not go away!
