9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman),
93
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | Looking for a yard that would have big bolt stake body bed some where in Pa or close. Thanks Jay | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Could use a little more info...are you looking for a modern or vintage bed? Original GM or aftermarket? What year range are you looking for? How long? Wood or steel sides? Mike B  | | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | I am looking for a vintage stake body bed with the front rounded corners that would have been on a 1952 chevy 6400 wood deck | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | You would have to be lucky to stumble across something like that at a modern yard.
Better luck posting on craiglist for some local 'north 40' type junk yards. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | That place looks cool, might have to go there for my next vacation. Looks way better than Disney World. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I live about 20 minutes away from that place. I can take a look for you if you tell me what you are looking for. Harry's U pull it is about 35 minutes away.. I go there. Mostly late model cars. They have a web site with an inventory: http://www.wegotused.com/?page_id=269Search by model/year | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I am in the process of making a new bed for my Canadian '47 flat deck. It has the original bed on it. I can send a load of pictures and measurements if it helps. 1.5 ton 137 inch wheelbase, 10 foot deck, drop sides a foot high. All wood with steel trimings. only a tiny bit rounded at the front. It has the upkick behind the cab, as high as the cab. I'll send a PM.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | pfarber pm sent
anyoldiron pm sent | | |
