| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | | | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | http://i1078.photobucket.com/albums...5-48D8-8E93-BD33BD146FD7_zpsuhqcrmng.jpgValve stem on 2 exhaust was sticking pretty badly for me- the stem was pretty gummed up Mike said it took a bit to get them all out of their guides- All were gummed up to some degree- two cracked guides that will be replaced as well. Looking forward to a fresh start | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Which cylinder had the crack in the head on it?? How do they fix the crack? Weld it or pin it??
John | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That looks like a pretty substantial crack to me. If it were mine, I would be looking for another head.
| | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | The machinist said it was worth repairing- I'm taking his word on this- he's the one doing the repairs- if it was too bad he would have told me to scrap it. The rest of the head was in better shape- I was surprised I didn't actually see that crack when I looked over the head before I brought it in. That crack is at #2
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I hear so many talk about all of the cracked heads. Do all cracks leak? Are the cracks caused by catastrophic over-heating right before the truck was parked for good?
| | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Stovebolt heads just have a nasty habit of cracking. Heads that were once considered to be junk get repaired now because the supply of good heads at the salvage yards has almost dried up. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If your guy is doing the repair himself, you should be all set. It gets a little murky when they send it out and someone else does the repair. There is no doubt that it can be repaired by the right person. Personally I was burned once on a crack repair and the memory will not go away! | | |
