0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 7 New Guy | | New Guy Joined: Jul 2014 Posts: 7 | Hey fellas. Just joined up here and posted in the welcome forum and got a response that I should perhaps post in here as well. My stepfather and I have a 63 GMC Panel that we used to travel in when I was a kid about 35 years ago. And we're into restoring it now. Really excited. Struggling right now with inner fenders. Got some repros, but they just don't seem to fit right. Has anyone come across this? Or have a vendor they'd recommend? Trucks in Ct... I'm going to try a post in Parts as well. Thanks in advance for any info, it's much appreciated! | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | What vendor did you try? I've used early classic enterprises for all my parts. No issues, yet. Welcome aboard, lots of help and knowledge here. You can build a whole truck from their catalog.
| | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | There will be two things working against you. The years on your truck have caused it to move an flex so it will not be perfect for even quality used parts. And, repo parts just don't have the quality that you want to expect (it is what it is). Bottom line get a 2x4 and pry or hit where you need to. I got my inner fenders from Classic Parts. Overall they were pretty good but I still I had to grind metal and pry where necessary. I also did not trust the metal from China so I had mine sandblasted and painted them with POR15. Then primer and paint. Stay after it and you should be good to go. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | If you go the OEM route, there were two different hood spring brace designed. the early years has a smaller brace, the 62-66 had a larger brace.
Jake | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | My suggestion for you, moving forward, is to try to buy OEM used parts whenever you can. They fit better, and putting vintage US made parts on your vintage truck will make you and the truck feel "right". If you don't have any local access via salvage yards, etc. try these fellas: Tony Smith: http://4-5-6chevytrucks.com/Rich Sisneros: [email protected] 1-719-267-4604 -or- 1-719-250-5057 Good luck to ya!  John | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Agreed, donor parts are THE way to go and it is nice to recycle. And 99% of the time cheaper. If you have to ship a donor from some nice dry place to your house, same ship cost as a new one from vendor and, of course, a donor has no tax. Don't forget, the repops will have Ford and Dodge metal in them, can't have that
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
