| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Hello.
Im working from underneath the car. Ive already removed the head on my 216 for valve job. Issue was low/no compression, so while Im at it figured I would do piston rings as well.
After removing the nuts that hold the bearing on the crankshaft, I pushed the piston up-but it did not come all the way out. It probably has another 1/4 of inch to go before top surfaces. I tried tapping it a little with a hammer and socket extension wrench on both the bottom of the piston head and then the empty hole where the bolt goes to hold the bearing to crankshaft, but didnt want to tap to hard in case I do damage.
Should I just hit/tap the piston out of the chamber forcefully? Is there danger of damaging it? Where should I strike it?
Advice is appreciated.
Judson | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is highly recommended to remove the ridge at the top of the cylinder before removing the pistons.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | How does the ridge come out? | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | use a piston ridge reamer from your flaps. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | so its basically just removing that upper lip of rust...its nothing that needs to be reinstalled after the piston is put back in...?
And what about the piston itself...should I just strike it with a mallet and piece of wood? Does it matter where I hit it?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its more then a ridge of rust. The cyl wears wear the rings contact it. There will be a ridge about1/8 in that the upper ring is down from the top of the piston. You need a ridge reamer to cut the ridge even with the rest of the cyl. After that the piston will come right out with a push from a stick or hammer handle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | If there's enough ridge to prevent the piston from coming out, there is a distinct possibility of enough taper wear in the cylinder to prevent a successful re-ring job. Many auto parts stores will rent you a reamer with a refundable deposit equal to the purchase price of the tool in case you decide not to return it. Once you ream the ridge, measure the cylinder taper by putting a piston ring into the top of the cylinder at the top of the ring travel and measuring the gap with some stacked-up feeler gauge blades. Then push the ring to the bottom of its travel with a piston to keep the ring square with the bore and measure the gap again. Subtract the bottom measurement from the top and divide the result by 3. The result is the cylinder taper in thousandths. If it has more than 5 thousandths of taper, don't try a re-ring- - - -rebore the cylinders and install oversize pistons. Jerry
| | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Thanks, guys. I ended up getting it out shortly after posting. I used a wooden dowel and it came out with a few taps. The rings actually look ok, but I guess looks can be deceiving, correct? I will go ahead and replace and see if it helps compression.
One question, however. Im just going to order the rings from Napa auto parts, but how do I know if the rings are the right size? It seems they come in different sizes, and I assume mine are stock, but should I measure them or something?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Use a 3-4 inch micrometer to measure the piston 90 degrees away from the wrist pin and at about the same level. It will measure about 3.497" or a bit more for a standard bore, and .020", .030" or .040" or more larger if the block has been rebored. Most oversize pistons will have the size stamped on the top of the piston once you get the carbon scraped off. Jerry
