1 members (VicZ),
231
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 2 New Guy | | New Guy Joined: Mar 2014 Posts: 2 | Found an unwelcome sight when taking the last parts off of the frame. The rear spring mount (cast iron part riveted to the frame) for the rear right wheel is broken to the point that the frame can be lifted right off of the shackle pin. Good thing the previous owner didn't take it over any large bumps...
My question is, are these mounts interchangeable with the 1-ton or 3/4 ton? I saw that the 1-ton has a 2.5" spring width vs. 2" for the smaller trucks. | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | ND Apache I believe I have that bracket you need .It's from a one ton 59. That's if you still need one. | | | | | Joined: Mar 2014 Posts: 2 New Guy | | New Guy Joined: Mar 2014 Posts: 2 | T-Ruck - Thanks for the reply. I can't PM you, so I started a new thread in Parts Wanted.
