1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 11 New Guy | | New Guy Joined: Jul 2014 Posts: 11 | Hey guys. I have a 51GMC 1/2 ton PU. I bought it from a body shop that used it for parts. Not much more than a cab and frame when I got it.
I've got a 2010 camaro LS3 with 6 spd that I plan to install. I have not been able to find any pics of an LS3 in one of these trucks. Would anyone know if the firewall needs to be recessed, tranny tunnel installed? My cab is on a rotisserie so it's impossible to do a trial fit.
I am installing a mustang II front suspension so the old gear box is gone.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I would mock things up. You have many other issues to work around such as brake and clutch pedals / linkage, steering shaft from column to rack and pinion. Each piece of the puzzle affects other pieces of the puzzle. | | | | | Joined: Jul 2014 Posts: 11 New Guy | | New Guy Joined: Jul 2014 Posts: 11 | I would mock things up. You have many other issues to work around such as brake and clutch pedals / linkage, steering shaft from column to rack and pinion. Each piece of the puzzle affects other pieces of the puzzle. I agree that it needs to be mocked up. I guess I'm curious as to how radical the modification has to be. Having built a Factory Five Cobra, I am scared there will be no room for the drivers feet and 3 pedals. (ask me how uncomfortable that is for a 6'-2" guy) Having measured the width of the LS3 (I believe it is similar to a 350 in size) it comes out to around 23-24" wide. If you recess the firewall that wide, it eats into where the accelerator pedal should go. It would be peace of mind if I could find someone who fit the engine into the stock engine bay without pushing the firewall back. I'm probably over thinking this at this point… Jerry | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | A straight six is a longer engine than a V-8. So the problem would more likely be fitting things between the fenders rather than firewall clearance. Depending, of course, on where you mount the engine. But a V-8, with room for a fan up front, should take up less room back to the firewall than a straight six. Here's a blown 350 in a AD truck. Lousy picture, but you should be able to get the idea about dimensions. | | | | | Joined: Jul 2014 Posts: 11 New Guy | | New Guy Joined: Jul 2014 Posts: 11 | Thanks guys! After seeing those pictures I feel confident that the only issues I may have will be the transmission tunnel. So for now, while the cab is on my rotisserie, I will shave the firewall at its current location and complete all the other welding, media blasting and epoxy priming. The tunnel can be installed after I get it on the frame and start mocking up all the other cut-outs I will need to put back into the firewall.
I'm feeling much better! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You're doing a fully custom setup, so only you can answer those questions. If you mount the motor correctly you shouldn't have to recess the firewall.
My dad has a 454 in his '52 with the stock firewall, so your LS should fit just fine. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Maybe you want to remove the gas tank from the cab and gain a few inches.
