5 members (Tronman, Phak1, 32Fordpuchoptop, Ponchogl, k2handyman), 88 guests, and 2 robots.
Topics128,042
Posts1,055,520
Members48,424
#1046335 08/01/2014 12:30 PM
Bleeding brakes on 1948 1/2 ton, if i push pedal from top to bottom how many times can i go up and down with the pedal before i have to fill the receiver?With out letting to much air into the receiver ,original brake system.Thanks
Not to many. A lot depends on how much fluid you're bleeding
out. The stock MC reservoir doesn't hold much fluid and it can
empty pretty quick if you've got a lot of air in the lines.
DG
Denny G
Sandwich, IL
I fill the master cylinder after I bleed each wheel. Takes a little more time but you won't run out and pump a bunch of air into the system.
Yep, it's a pain. Try bleeding one like mine that has 8 wheel cylinders.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
ODSS President
ODSS President
Do yourself a favor and buy a set of SPEED BLEEDERS, best money you'll ever spend.
~ Cosmo
1949 Chevy Half Ton
I'll second that Cosmo. The only problem with the speed bleeders
is you still need to get the wife out in the garage cuz you
can't see when the bubbles quit in the jar. I've tried a mirror
but having someone at the wheel watching for a solid stream is
the best.
DG
Denny G
Sandwich, IL
ODSS President
ODSS President
Denny,
That's how I get my exercise, I do about 3-4 rounds per wheel every year to purge out the old and introduce the new. BTW, my tubing is clear, I don't look for bubbles in the jar, I look for them in the clear line, works great!
~ Cosmo
1949 Chevy Half Ton
