1 members (Otto Skorzeny),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10458 04/24/2002 4:53 PM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | Want to change the 20 yr old oil in the dump truck, which one? | | |
#10459 04/24/2002 9:21 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | 216's are supposed to use 20w in most climates.
#10460 04/25/2002 12:45 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | If that truck really has 20 year old ND in it you better stay with 20 W ND. HD will break lose all the dirt. Brings to mind all the stories my father told of guys blowing engines by changeing to HD oil.
if it dosen't need fixed, break it
#10461 04/25/2002 3:06 AM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | I have no clue what is in it. But the truck has been sitting since 1979 or earlier. It was like water coming out, but I saw no chunks or sludge. | | |
#10462 04/25/2002 5:26 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Since summer is coming, i would run at least SAE 30. Detergent or not? Look at the inside of the filler cap. If it's clean, someone has probably been running detergent oil and it won't hurt to stick with it. Does the engine have an oil filter? It will keep most of the dirt out of the crankcase. In my case, my 216 was using a quart of SAE 30 every 300 miles, so I switched to 20w-50. Oil use dropped to a quart in 500 miles.
If it's been 20 years since the engine ran, I would remove the rocker cover and pull the coil wire. Crank the engine until oil comes out through the valve train. Then replace the cover and start the old gal. And change the oil at 500 miles the first time.
Fred 52 3600 69 C-10
#10463 04/25/2002 5:56 AM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | by now most old engines have had hd oil in them allready cause you pull in a gas station and ask for a quart of nd oil and the station guy sez what heck is that?? so hd gets put in anyway. in the summer time i like 20w-50w racing oil in a old high milage motors
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#10464 04/25/2002 1:38 PM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | This thing hasn't seen a gas station since the 70's I went ahead w/ ND this time. And I doubt it will see over 50 miles in the next year. I may haul some on the farm but that is about it for this ol' rig. The farm is only 100 acres. | | |
