| | | Forums66 Topics128,154 Posts1,056,857 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | I have a Rochester 1bbl carb that always leaks around the fuel filter housing. The original gasket was one of those thin metal round rings. The rebuild is a round gasket style.
Has anyone else run into issues with the filter dripping from the carb (not the fuel line side)? Any good fixes? Seems to keep leaking even with a replacement gasket.
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Sounds like you may have a crack in the carb. Time to get out the magnifying glass.
| | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Thanks Carl...
I do not think it is a crack in the carb, only because it stops leaking when I replace the little round gasket... then about a month or so later, it starts to leak again. I could be wrong, but I am hoping I am right. Thanks for the information.
Does anyone know where I can get more fuel filter ring gaskets besides from a rebuild kit?
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | look in the part store on one of those racks with all the grommet,screws,door handles. they usually have them there are behind the counter
Tommy 59 apache 1/2t 261 short stepside | | |
