2 members (frogfarmer, Otto Skorzeny), 102 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
I have a Rochester 1bbl carb that always leaks around the fuel filter housing. The original gasket was one of those thin metal round rings. The rebuild is a round gasket style.
Has anyone else run into issues with the filter dripping from the carb (not the fuel line side)? Any good fixes? Seems to keep leaking even with a replacement gasket.
1960 Chevy Apache (C10)
1965 Chevy C30 Dump Truck
1966 Chevy C30 Tow Truck
Sounds like you may have a crack in the carb. Time to get out the magnifying glass.
Thanks Carl...
I do not think it is a crack in the carb, only because it stops leaking when I replace the little round gasket... then about a month or so later, it starts to leak again. I could be wrong, but I am hoping I am right. Thanks for the information.
Does anyone know where I can get more fuel filter ring gaskets besides from a rebuild kit?
look in the part store on one of those racks with all the grommet,screws,door handles. they usually have them there are behind the counter
Tommy
59 apache 1/2t
261 short stepside
