4 members (3800GUY, Guitplayer, klhansen, Otto Skorzeny), 81 guests, and 3 robots.
Topics128,153
Posts1,056,847
Members48,456
My 59 235 has good oil pressure. When I drive for a distance (a couple miles)the lifters start to rattle under load,climbing etc. When I let up and coast they quiet down.When it starts rattling the oil pressure still reads 30.when it gets real bad it starts to go down to about 15,but not as a rule.Some times the day after a long drive it will rattle at startup and stay rattling until the oil gets to the lifters and then it quiets down. The pickup screen is ok,the pressure is good so I don't think it's the pump. I'm guessing that for some reason the oil is restricted from reaching the lifters.I plan on removing the oil pan and valve cover this weekend and do a search. What should I look for?I will remove the pump and visually inspect it as well as the pickup tube.I heard something about a head bolt that is drilled for oil passage on some of these.Is this on my engine? Where would I find it? I really need help here. I am driving this every day but only short trips. I'm afraid I'm going to ruin this rebuilt engine. Help!---Jack
I would recommend you start by reading what I have written about this on my BLOG
My Blog
Thanks Dave. That is some very helpful information.---Jack
Pre '68 Dave #1047193 08/05/2014 4:54 PM
I'm afraid to say it. I might jinx it.It worked. I followed the procedure in your blog for making a groove in the pushrods to let air get out of the lifter and it worked.I drove the truck a bit yesterday and climbed some hills today and the ticking is gone.I hope this is the end of this phase of renovation so I can move on to other things. Like the from end,the gas gauge,the rear springs.---Thanks ---Jack
CJSTP #1047259 08/05/2014 9:22 PM
Very good to here!
These projects are never done nor should they.
My Blog
CJSTP #1047504 08/06/2014 7:41 PM
Originally Posted by CJSTP
I followed the procedure in your blog for making a groove in the pushrods to let air get out of the lifter...
Congratulations Jack!
May I ask what you used to make the groove? How big of a groove are we talking about here?
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
CJDublu #1047525 08/06/2014 9:28 PM
I used a dremel with a small cutoff disc. I just cut a very shallow groove the thickness of the disc from the center out to the edge.Less that 1/16" deep.Just a path for the air to escape.---Jack
