10 members (Otto Skorzeny, RLB, Hotrod Lincoln, Wayne67vert, fonz8261, klhansen, joe apple, Guitplayer, cmayna, Lightholder's Dad),
97
Mod | | | Forums66 Topics128,192 Posts1,057,229 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 21 | Has any one installed a mid 90's crown vic ifs suspension in there advanced design truck. Would love to know if its good, bad or just go with the mustang two ifs. I recently accuired a 95 crown vic for free. I have the complete car for all its parts and suspension. Any info greatly appreciated | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't personally know anyone that has done this, but the guys at Gas Monkey Garage put one under an old Dodge truck. Seemed like it fit just fine on the frame. Having worked with them on the stock application, that front end is very easy to service, handles well, and should work very nicely under an AD truck. It will certainly outperform any M2/Pinto based frontend. You will want to go through it, replace balljoints/tierods/sway bar links, as they are not serviceable factory and tend to wear.
Bill Burmeister | | | | | Joined: Mar 2012 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 21 | Thanks Bill I'll check it out. Soon as i get it all apart and fitted I'll let you now how it went. Thanks again | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I have seen one in place on a truck that isn't running and could probably get the guy's email address if you'd like. I am sure he has pictures. I was surprised how well it fit the frame and looked but, like any ifs swap (that I have seen so far), it doesn't look like a precise swap. | | | | | Joined: Mar 2012 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 21 | Yeah that would be great if you could get me that address. Would be interesting to know what I'm up against for the swap. Thanks again! | | |
