| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Got the windows in. the window guides channels etc...My only issue is that with all the new channels felt etc....the windows are tight tight tight !! no way these windows will roll up and down. I took the windows and slide them up and down numerous times until they got somewhat easier.They are still stiff. Any ideas ? also I still need to set the windows.So how does this taping thing work? you put the tape in the channel along the window and when it is set you pour solvent/ gas on it and let it set ??? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1951 truck? 48-51/52 Shop Manual - window glass use gasoline to remove old glass use light oil to "set" new glass | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Give the setting tape several days to really lock the glass in tight. After 24 hours, you can handle the parts, but it takes days to really lock in. With the proper thickness setting tape, you should be able to easily mate the glass to the channel. Only slight tapping with a rubber mallet is necessary. If too difficult then the setting tape is too thick. The tape the common vendors sell is much too thick for any part of the truck.
I cant really remember, but I believe I used 1/32" thick tape for both door glass and vent windows. Went together easily and locked tight after several days. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | If you are referring to the fit in the run channel, thats because the glass used today is thicker than that 30 years ago. The best thing I've found is WD 40 or a good silicone spray. Spray channel and run window up and down to work in and wear run channel in. Also, be sure the front, back and top of the glass is seamed good. You need a rounded edge (look at the glass in a newer car/truck). You can use 80-120 wet or dry to hand sand if necessary to relieve these edges. Be careful not to sand the outside of the glass where it will show! John
