1 members (cmayna), 149 guests, and 0 robots.
Topics128,114
Posts1,056,287
Members48,439
What is the difference in the two? :confused:
ol'55,
The best answer in this forum usually comes from MARTINSR
Primer surfacer and epoxy primer are discussed in the link above.
Tim
Junior Member
Junior Member
"Primers" are materials that promote adhesion. For painting automobiles, the primer promotes adhesion of the color. Without the primer, the color would quickly fall off.
Many materials have multiple characteristics. A "primer-surfacer" promotes adhesion, and also has enough solid content to allow sanding of the film to perfect the surface prior to painting color. A good quality 2K primer surfacer can be topcoated without any further application of sealers. Others are primer, primer-sealer, or sealer....
"Epoxy primers" have excellent adhesion characteristics, excellent corrosion resistant characteristics, and great durability. They work well as a barrier coat between old subcoats and new applications. They have good filling characteristics, and can be sanded and used as a surfacer, but I've never liked sanding them.
Tim
