7 members (MickeyP, David Bush, kades51, Gdads51, cmayna, Donf, 3800GUY),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | All of a sudden I go to use my head lites and they are not working, nor the parking lites. Vehicle is a 52 PU, new 12 volt system, 100 amp one wire alt, everything else is fine. headlite switch is a chevy duty 12 volt PN 53-156. Is it the switch, I'm about to buy another switch.
52pu
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Sometimes a bad dimmer switch will cause this. I would bench test the headlamp switch, before buying one. Apply power to it and use a test light.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dimmer won't affect park lites, and the switch doesn't care if you use 6 or 12V on it, but the repro switches aren't the best quality nowadays so I'd suspect it, but using a meter to find out where the voltage disappears would be better than just throwing money at the problem, could just be a loose connection at the switch
Bill | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | You can jumper across the switch. Just take a wire from the hot battery side to the out to lamp side. No light something else is wrong. | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Figgured it out. Pulled the switch down, on the back of the switch was a relay, the bottom nut had worked loose not allowing good contact. Tightened everything up, works now. Thanks for everyone's input.
52pu.
