| | | Forums66 Topics128,151 Posts1,056,989 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi,
I just put a 350 in my 56 Chevy pickup, connected to the stock SM420 trans. So, it is in the factory location and has a factory (repop) 1956 V8 thermostat housing. I am reusing the 235 radiator so the original v8 hoses will be too short. Can anyone give me P/Ns for molded hoses that can be made to fit? Thx. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Mock one up and go to your flaps.
They will (usually)let you paw through rack of hoses. Find a hose that has a section you can cut out to make what you want. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Welcome to the Stovebolt  I have the same set up in my '56 3100 and I used the following hoses... NAPA 7240 Upper (has one 45 degree bend, will need to be trimmed to length). NAPA 7694 Lower Mike B  | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Awesome! Thanks for the quick responses. Off to NAPA after work. | | |
