8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | On my 55 1st, the rear hood support isn't affixed to the sheetmetal so you can lift it off the bracket. Should this be stuck to the support with epoxy or some other adhesive as I have seen in other applications. There doesn't appear to be signs there was any "stick-um" on it before plus I don't know if the cowl seal would lift the sheetmetal off the support when the hood was closed. I remember seeing a fiber cushion material attached with a black tar as a metal to metal separator on hoods on some rigs. | | | | | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | I was wondering the same thing. I am starting to work on my hood on '50 and the sheet metal does not touch the brace and there is nothing between them. On my '51, there are some foam rubber-type pads between the brace and hood. Someone on here should know what should go in there. | | |
