5 members (NJC, FAST55, tclederman, Joe H, lumbersawyer), 64 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#10449 04/19/2004 10:39 PM
Did GMC ever make a hydramatic flywheel to bolt to the 4 bolt hole crankshaft?
My 55 gmc has a 6 bolt hydramatic flywheel and the 52 gmc 248 that wants to power it has a 4 bolt crankshaft :mad:
#10450 04/20/2004 5:33 AM
I do not recall,,,
do 4 of the 6 holes line up?
#10451 04/20/2004 10:27 AM
Mechainiac
No 2 holes line up but the flywheel/flexplate 6 bolt has a recess in it for the end of crank 3" circle and the crank shaft 4 bolt has the a lip on the 4 bolts holes so flexplate would not fit flat
looks like the 248 crank takes manual shift only.
Ever hat a 53 hydramatic apart? Did the military have hydramatic in the 40s and early 50s? Bill
#10452 04/20/2004 10:30 PM
I have had a couple of these units apart. one chevy and one GMC. I know the Chevy has 6 bolts but I do not remember if the GMC had a 4-hole flywheel for the Hydramatic.
Yes, the military did have Hydramatics in use in many rigs including tanks grin
http://www.futurliner.com/trans.htm
http://www.drivetrain.com/transautogmapp.html
http://www.autotran.us/hmkits1.html
#10453 04/21/2004 12:17 AM
Mechainiac
Looks like my 52(248) will take manual shift only
I did email autotran, and have made a few phone calls. gmc went to 6 bolt cranks in the hydramatic in 53 then all 6 bolt soon after. a year or two newer 248 and it would have the 6 bolt crankshaft.
thanks for your help and the web sites. Bill
#10454 04/21/2004 12:31 AM
A couple last shots: try Stovebolt Engine Co., Patricks, and the Buffalo (info on Inliner's site.) They are involved in the automatic adapters for early engines and may have some information. I believe they make flex-plates to do this.
#10455 04/21/2004 2:12 AM
Splashoil
I see on the Bufflo site, (custom flexplates). I will call them tomorrow they may have done this before or know if it can be done. thanks Bill
#10456 04/21/2004 2:23 AM
He is a one man shop, does very good work, knows his stuff. You won't be disappointed if you decide to use him. Good luck! grin
#10457 04/21/2004 10:34 PM
Splashoil
Bufflo said the same hydramatic won't work with 4 bolt crank.
So I Will have a rebuilt 248 allready to put in my next GMC with the manual shift tranmission.
I have the military 302 that should bolt up to the 55 hydramatic it has the 6 bolt crankshaft. Got any tips on that motor swap? Bill
