5 members (Mike B, ShopRag, Youngin' Tut 59, klhansen, 1 invisible), 98 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
Anyone recognize what this is, or could lend any info about it? This one was located in the wiring leading to the heater, and there was another one somewhere behind the dash
front
Back
12v to 6v converter/reducer (is that a mounting post) ?
fan speed-control rheostat ?
Could be a voltage reducer for using a 6V heater in a 12V system. I have not seen anything similar on my 49 1/2T 6V system.
Ed
I knew you guys would help me out! I've just never seen one like that (until now). Is there a way to test to see if they are still good, before re-using or replacing them? (Electrical novice here)
Ex Hall Monitor
Ex Hall Monitor
Connect it to a 12v source & read the output voltage on the other side. If it reads 6v it's good. I wouldn't hold it in my hand while testing it though. It bleeds off the current as heat.
in order to meter the voltage, you need to have it hooked to a load .... start with a resistance check with an ohmeter, not sure the resistance used for the heater, but if it's not an open circuit it's still usable .... if there's another for the gas gauge it'll be about 40 ohms
M Online: Content
They also should be bolted to the body somewhere so the heat-sink stud can give up it's heat.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks guys! There was one going to the gas gauge (which wasn't working at the time of wires being torn out). I'll get these things checked within the next few days (hopefully) and I'll report back with any findings!
