| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 30 Junior Member | | Junior Member Joined: Mar 2002 Posts: 30 | I just acquired a used windshield frame for my 42. It's in pretty good condition except for some small rust holes in the gasket and glass channels and a few pin holes in the exterior of the frame. What's the best solution for repair, use an epoxy or just sand blast well, coat with por-15 or zero rust and install the gasket and set the glass? Thanks for the help! | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | My 37 was the same way. It had rust holes all along the bottom half. I sandblasted the inside and out real good to get all the rust and loose junk out then filled it with a liquid steel epoxy type stuff. I can't find the reciept to see just what it was. I not sure but it might of been JB Weld I poured in it. I know I used quite a bit of it, but it sure stiffened up the frame. Joe | | |
