| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10449 04/19/2004 10:39 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Did GMC ever make a hydramatic flywheel to bolt to the 4 bolt hole crankshaft? My 55 gmc has a 6 bolt hydramatic flywheel and the 52 gmc 248 that wants to power it has a 4 bolt crankshaft :mad: | | |
#10450 04/20/2004 5:33 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I do not recall,,, do 4 of the 6 holes line up?
#10451 04/20/2004 10:27 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Mechainiac No 2 holes line up but the flywheel/flexplate 6 bolt has a recess in it for the end of crank 3" circle and the crank shaft 4 bolt has the a lip on the 4 bolts holes so flexplate would not fit flat looks like the 248 crank takes manual shift only. Ever hat a 53 hydramatic apart? Did the military have hydramatic in the 40s and early 50s? Bill | | |
#10452 04/20/2004 10:30 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I have had a couple of these units apart. one chevy and one GMC. I know the Chevy has 6 bolts but I do not remember if the GMC had a 4-hole flywheel for the Hydramatic. Yes, the military did have Hydramatics in use in many rigs including tanks http://www.futurliner.com/trans.htm http://www.drivetrain.com/transautogmapp.html http://www.autotran.us/hmkits1.html
#10453 04/21/2004 12:17 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Mechainiac Looks like my 52(248) will take manual shift only I did email autotran, and have made a few phone calls. gmc went to 6 bolt cranks in the hydramatic in 53 then all 6 bolt soon after. a year or two newer 248 and it would have the 6 bolt crankshaft. thanks for your help and the web sites. Bill | | |
#10454 04/21/2004 12:31 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | A couple last shots: try Stovebolt Engine Co., Patricks, and the Buffalo (info on Inliner's site.) They are involved in the automatic adapters for early engines and may have some information. I believe they make flex-plates to do this. | | |
#10455 04/21/2004 2:12 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Splashoil I see on the Bufflo site, (custom flexplates). I will call them tomorrow they may have done this before or know if it can be done. thanks Bill | | |
#10456 04/21/2004 2:23 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | He is a one man shop, does very good work, knows his stuff. You won't be disappointed if you decide to use him. Good luck!  | | |
#10457 04/21/2004 10:34 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Splashoil Bufflo said the same hydramatic won't work with 4 bolt crank. So I Will have a rebuilt 248 allready to put in my next GMC with the manual shift tranmission. I have the military 302 that should bolt up to the 55 hydramatic it has the 6 bolt crankshaft. Got any tips on that motor swap? Bill | | |
