3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
This is a dumb question but how do you hook up the lighter? Is it just the one wire that screws on the back and thats it? Just want to make sure. Thanks guys
yes, the hot wire to the center pin, usually requires a special connector cuz it's deeply inset - the case is the ground to the dash
Originally Posted by Harold46
DAD550
The lighter base you have is a standard replacement for any car/truck.
You need the following connector which was made for this type hook up (threaded screw). It just pushes on and will not fall off. It is insulated and is the eaisest connector I have ever used.
It is AIRTEX Part # 1P1063
You can get it from O'Reilly Auto Parts
http://www.oreillyauto.com/site/c/search.oap?keyword=1p1063+[/color]
Rock auto parts also has it.
http://www.rockauto.com/catalog/raf...partnum=1P1063&a=FR903-1P1063-856074
Check Ebay or just Google Airtex 1P1063
yahoo
Harold
...link...
Thanks again I will check out my local O'Reillys for the part.
