Thanks guys...
I may not be the one to give advice, as I have gone against all of the things I have read about painting a vehicle.
But I already had the compressor and gun, so I used what I was familiar with.
• I used PPG's K36 Primer/Surfacer, then DAR Acrylic Enamel (Single Stage). The Dark Blue is a metallic, and the white is not.
• My compressor is a 30 gallon, 6 hp, oiless Craftsman. (Have to wait for it to catch up a little)
• The gun is just a $49.95 Husky special siphon feed from Home Depot.
• I do have a Sears water trap between the compressor and the hose.
• I have also used the disposable filters between the hose and gun. But not everytime. (Only cause I forgot)
• A friend took the cab off in his shop and did the major metal replacement (floor pans-cab corners, etc., then put it back on and I started the filler/prep work.
• I just have a small garage, so I put up some plastic sheeting over my bench and parts, etc., used a fan to pull some overspray into the back 40, Wore a respirator-glasses-gloves, then "went for it"!
I have had a little experience with painting flat panels for use in the sign business, but this is my first vehicle. I haven't buffed or polished yet and I am very pleased with the results.
There ya go...Don't do what I did (and am still doing) and you should be alright!
Here's another angle...
http://pic5.picturetrail.com:80/VOL92/799532/3957505/69466970.jpg
