0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | My oil pan got dented and it pushed the tube up so it wasn't picking up oil very well. I pounded out the pan and straightened the tube but it still sits too low. It's resting right in the bottom of the pan and I think it is restricting flow. I searched parts suppliers but I can't seem to find a source for a new tube and screen. I think I either need one of those or a different pan. My motor is a 59 235 full pressure with hydraulic lifters. Anybody know where I can find parts?---Jack
| | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | This is a picture I took of the tube before I repositioned it. It is threaded into the pump so it moved easily. With it horizontal however,the screen sits right in the bottom of the pan. I had to pound it out to get the pan back on.There is slight possibility that the pump isn't installed all the way. That may provide the proper clearance. I'll be checking that next.---Jack photobucket picture
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | The pickup should not touch the bottom of the pan but even if it does, the flow won't be restricted because of the design of the pickup. Put a floor jack under the pickup with a piece of 2X4 on it and push the pickup tube up a little to create 1/4" of clearance or so. Jerry
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Use a hammer one or two sizes larger (BFH if necessary) to restore the bottom of the oil pan back where it belongs. It would also be a good idea to make sure that the sealing surface of the oil pan matches the bottom of the engine block to make sure you won't have any leaks. That will be difficult to do with the engine in the truck and even more difficult to pound on it to make it fit. A spare block would come in handy for this operation. Carl
| | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | I'm not quite sure how to describe this. I already reshaped the pan. The pickup tube is threaded into the side of the pump so when I push up on it it threads further into the pump but because of the shape of the tube it goes up at an angle. When it is in far enough for the bend in the tube to clear the pan bottom the screen is tipped up at an angle several inches above the bottom. I'm trying to say that it doesn't fit my pan. Where can I find a different tube/screen?Or maybe a deeper pan? Is there such a thing?---Jack | | |
