3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I have some rusted through areas on my frame rails. What's the best way to reapir these. Not real large. Coin sized. Thanks | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | If you mean rusted all the way through, as in a hole in the frame, you need to weld in reinforcement plates. Go to an expert. A screwed up frame is your worst nightmare. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I had a rusted frame, but it hadn't twisted or bent (to the best of my measuring abilities) so I just reinforced it with angle iron. http://www.homestead.com/chuckthetruck/page4.html | | | | | Joined: Mar 2002 Posts: 9 Junior Member | | Junior Member Joined: Mar 2002 Posts: 9 | Does anyone know how many cross members a 1940 gmc should have? Also the frame is pretty badly rusted on my truck. I can possibly replace it witha 1937 chevy 2ton frame, that's in mint cond. Would that frame fit under a 1940? | | |
