10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible),
58
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Can someone give me a couple of location dimensions for mounting the original style radio antenna on the cowl fender extension? I have three used cowls, and they have all been drilled later in life in the wrong place.
The original antenna would have come with a template to use, but that is not supplied with replacement parts.
A measurement down from the top of the cowl, and from the front of the cowl, either to the actual antenna, or to the hole centerline would be good. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Thanks Hot Rod John, the pictures show the OEM location as well as a typical aftermarket one. Obviously when someone drills their own hole to install an aftermarket antenna, they don't stop to think about exactly where it should go. The OEM has a bracket to hold it in place, and it has to be close to the front of the cowl in order to use the bracket.
So I have two cowls in my shop that have the hole punched way too far inboard, and one on the truck, which is at the paint shop. I pulled up my photos of the truck in progress, and it appears that the one on the truck may be drilled correctly. Unbelievable! I'll find out next week.
Looks like the one I put on the truck is an OEM hole! Great!
