Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
Can someone tell me the bolt pattern and distance center to center of holes top and bottom on 1958 chevy truck transmission 261 6 cylinger.
Thanks for help
The following link should help. All chevy and gmc trucks had this bolt pattern from 1948- 1967 ish. Passenger cars also got this pattern sometime in the 1950s. Gm continued to use this pattern through the 80s and 90s on certain moldels like the camaro, firebird, and s10 pickups. Some cars and trucks had the same bolt pattern, but a larger hole in the middle starting around 1967.
http://www.allstategear.com/Breakdowns/Chevrole_%20Muncie_4_speed_Bolt_Pattern.jpg
I assume this view is looking from the bellhousing toward the transmission... You will likely have to flip the measurements from left to right to get the bellhousing measurements.
