8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#104478 04/27/2005 2:05 PM
Lord Almighty, I have pretty much given up on trying to get my hood back on right. As previous posts have stated this is the WORST job of restoration. Way too many variables and not a real precision piece of work to start with. Having undone the front clip for the third or so time, tweaked all the tweaks that the manual tells me to, it still is marginal at best. Any help before I call it quits?
#104479 04/27/2005 2:26 PM
Anonymous
Unregistered
Anonymous
Unregistered
#104480 04/27/2005 7:04 PM
Sorry I can't help with a solution but I may be able to help you come to terms with the situation if it's to do with the hood springs. (In the words of the well-known prayer, "Oh Lord help us to accept those things we cannot change, like out of alignment Chevy truck hoods.")
I had the same prob. Faithfully followed the instructions, got it perfectly aligned, tightened everything wrist-breakingly tight, checked the alignment again, confirmed it was perfect, bolted the support springs up, closed the hood--and gaps opened up at the cowl. Repeated this numerous times (presumably also repeating the same mistake, whatever it was), until I ran out of swear words, gave up, and removed the springs. Now I use a makeshift prop to hold the *#@*$#* hood open. Advantages of new arrangement: (1)good exercise lifting a heavy AD hood without sprung assistance (2) additional income from work-out classes for elderly neighbors with atrophied biceps (3) able to sleep again and (4) wife no longer refers to me as Mr Grumpy.
Good luck. If you discover The Secret Of Eternally Happy Hood Alignment please let us know.
#104481 04/28/2005 1:54 PM
I guess with a factory manual that gives you a one and a half page opus on hood adjustment you just have to take what you get and don't pitch a fit.
#104482 05/07/2005 9:24 PM
Have you tried making some shims for the center reinforcement bar in the rear of the hood it helped me on a 53 AD that I couldn't get to line up to the cowl.
