2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I remember back in the 80's when I first got the truck I was contemplating a floor shifter to replace the column shifter. But I can't seem to find them anymore, I once saw one on EBAY, but my question is what is the stock transmission in a 53 3100. I can find a shifter for a 55 and up 341 transmission, but I looked all over both my transmissions, and can find nothing that would even come close to telling me what I want... I will call hurst today. But I am afraid they will have no idea either. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | What year truck and what transmission? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the stock three speed that comes in a 53 3100. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There is a thread in HiPo concerning 'Floor Shifter Options' that may interest you. If you have any information please post it there. I am going to a lot of trouble.. A LOT of trouble to get the column shift to the original 4 speed floor location. I am very close but its not easy. A few weeks and I will be done with the 2nd attempt. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | One of the finest guys I know, Cosmo has converted his 3-speed to a floor shifter. I'm sure he will see this and give some guidance. If not, send him a PM.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I made a very good center floor shifter using a used B+M 3 speed shifter that performed flawlessly for 14 or so years in a daily driver only vehicle. I finally went back to a column shifter using heim joints that works easier than a floor shifter. I made my own rods and used the heim joints to upgrade from a 90 degree angled rod into a wallowed out hole. My upgrade on the column is the simplest solution and I have decreased the throw as well. I'll post pictures of the floor conversion if you are interested.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Cosmo, I would be interested in seeing pics of the mods which you made to the column shifter. Carl
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes pictures would be nice. I kind of need to get the little shifter box on the column out of the way. It's gonna run into my intake setup. I was actually looking for a purpose built unit, but I may just have to make one myself... Once I figure out how to post pictures I have several I would like to post.
| | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I actually shortened the 1-R shifter arm as it was interfering with the firewall side of the Edelbrock dual intake. Here are the shifter arm ends with a 'Shift-Tite' swivel. I threaded and bent the rod a little at a time to avoid interference. These are the heim joints. Works like a charm for a year and a half. I really like the column shifter as it leaves the floor clean and most people have no idea how to shift a three-on-the-tree. That's a '69 3speed Saginaw with Borg-Warner overdrive, the 'holy grail' of transmissions, all-synchro, very stout, positive shifting.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Cosmo, what did the shortening of the 1-R shifter arm have on the throw of the column shifter lever (longer or shorter)? I have a '66 Saginaw three speed and the throw of the column shifter is real short for 1-R shifts. I have an extra shifter box with two short arms and was thinking about swapping it in place of the stock one in hopes of restoring the proper column shifter throw. Carl
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I think I found one or two that I can make work, mr. gasket, and hurst both have a "UNIVERSAL" shifter, that I am pretty sure can be made to work. | | |
