8 members (MNSmith, lumbersawyer, Hotrod Lincoln, Shade Baby, klhansen, Mike B, 2 invisible),
123
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Here's a side pic of the adapter in place (no gasket yet): http://i.imgur.com/s3TXE9l.jpgAt the top, where one of the bolt holes are drilled into the block, there is a small gas on both sides that is above where the gasket or silicon would go (above the water intake). Is this correct/the adapter doesn't sit flush against the engine at the top? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Gap is correct, no problem.
See the USA in your vintage Chevrolet! My Blog | | |
