1 members (1 invisible),
156
Mod | | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hi All,
I'm working on a 1951 216 (to put into a 1947 3100). There is a "jumper tube" near the oil distributor. Does anyone know where a new/replacement can be found, or the best way to fabricate one?
Many thanks,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2004 Posts: 29,957 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,957 | IIRC, it's an oddball diameter, maybe a 7/16" OD? I believe you can change the compression fittings in the oil pump and the block to 1/2" OD, and use either copper or steel tubing and a tube bender to fabricate one. Be careful to allow for clearance for the crankshaft. Jerry
Edit: If you're talking about the small-diameter tube that goes through the water jacket to the lifter galley, several of the online antique parts vendors sell a kit with new tubing and all the necessary fittings to replace it.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | This may be what your looking for. Good luck Dave | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'd bet that 3/16" line is what Bill is looking for Jerry, the same one Dave has link him to at Jim Carters. First time most people run into that they think there is a separate short line at the oil distributor or a separate line in the lifter galley. They feel the urge to take them off and clean them and soon discover that it was one continuous line that starts at the oil distributor-makes a 100° bend-goes straight thru the water jacket-bends up 90° in the lifter galley-goes thru the head and terminates at the rocker arm shaft connector. Once again, when all else fails....read the instructions. Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bill,
You might want to post a link to photo of the line you are referring to (and, where it attaches to the block/etc).
This will allow you and others to be more certain that you are discussing the same things.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thanks guys, I'll try to post pictures tomorrow.
Never, never, never, never give up. - Churchill | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Here are two pictures that show the old tube (sorry pic loaded sideways) and the ports on the "new" engine. Any help identifying where to get one of these is appreciated. Thanks, Bill
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2004 Posts: 29,957 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,957 | That appears to be the tube that goes through the water jacket to supply oil to the rocker arms. The kit shown above will have all the bits and pieces necessary to replace it, and it's a one time use item that cannot be removed and reinstalled without damaging it. Jerry
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thanks Jerry, and all.
I've never gotten deeper into a 216 than adjusting the valve lash and bearing clearances. This is "major surgery" from my perspective, but it should be entertaining.
Best regards,
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2004 Posts: 29,957 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,957 | The trick is to tighten the compression fittings onto the tube just enough to prevent coolant leakage, not cinch down on them as tight as they'll go. Once they're crimped onto the tube, there's no way to undo the process, so wait until you're sure everything is fitted properly before you final-tighten those little compression sleeves. Particularly, watch the clearance of the tube near the pushrod cover- - - -no touching! Jerry
