1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | I finished the replacement of the lower hinge pillar panel on my 54 along with the inner, in to out and outer cowl panels and I am not able to get the lower portion of the door to pull in flush with the outer cowl. I have about a .25" to close up.
The cab and door and lower left door hinge are not from the same vehicles.
The door opening was fully braced prior to replacement and the opening measurements are now the same as before the pillar was cut. No weatherstripping is in place at this time.
The available options as I see them are: 1. Bend the hinge arm inward at the first bend, 2. Slot the holes laterally in the hinge mounting plate, 3. Get another hinge and see if does any good (anyone have one?), 4. Modify the hinge pocket to give it some more lateral adjustment (Last resort).
Has anyone else fought this battle? The door fits fine from the belt line up. The fact the pieces are from different trucks could be a factor. I do have another door to try but it is not in as good a shape as the original. Thanks for the help. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | ChucktheTruck, In your opinion/experience, is there a quarter inch of inward/inboard adjustment available in the lower hinge? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Have you rebuilt your hinges? I wouldn't make any adjustment until you do, they are prone to wear.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The hinges are tight with no slop/play so I am not planning on rebuilding them other than to replace the spring on the uppers. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | By bending the hinge a 1/4" is easy. I had also tried slotting the holes and it didn't cut it. | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I am in the process of hanging and adjusting my doors. The drivers side went right in and was a great fit. However, the passenger side was a different story. The front edge of the door is flush with the cowl, with about a 1/8 inch gap that is uniform top to bottom but the upper rear edge hits the frame of the door opening. What is the adjustment for this? | | |
