1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | I have a 54 Chevy 3100 pickup that I am restoring. Does anyone know if the inside of all the fenders are supposed to be body color or did they come black? Same question for the wheel side of the inner fender up front and the bedside behind the tires in the back. The truck will be red but I'm not sure what to do inside the wheel wells. Thanks !!! mh
54 Chevy 5 window - 46 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Inside of of fenders were most likely flat to semigloss black (some people recall that there was generous overspray of body color, too).
Inner fenders were black on both sides (semigloss?).
My guess is that bedsides were body color, even behind fenders.
Tim | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I think the semi gloss black was the primer. The NOS parts I have seen are the same color perhaps they where dipped in primer and sprayed body color. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Metalman,
What was the primer that was used? It is hard as h*** to get off.
Tim | | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Thanks for the info! I'll go with the semi-gloss, it will be alot easier anyway. mh
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I do not know but I do not think it comes close to the quality of what we have today. I think the parts where dipped because a lot of the nos parts have runs. They might have done a little sanding as needed on the exterior and sprayed body color. A low gloss black looks close. It is by no means flat. Ray | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Is it possible that they could vary from plant to plant / month to month / supplier to supplier?
My first '49 had very glossy inner fenders. I ended up stripping and painting with gloss black Centari paint. When people would look under the hood the responses would always vary from "hey, someone got it right" to "that looks dumb - they were never that glossy" :rolleyes: | | |
