1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#104384 07/17/2003 10:22 PM
I have a 54 Chevy 3100 pickup that I am restoring. Does anyone know if the inside of all the fenders are supposed to be body color or did they come black? Same question for the wheel side of the inner fender up front and the bedside behind the tires in the back. The truck will be red but I'm not sure what to do inside the wheel wells. Thanks !!! mh
54 Chevy 5 window - 46 Chevy 1/2 ton
#104385 07/18/2003 1:00 AM
Inside of of fenders were most likely flat to semigloss black (some people recall that there was generous overspray of body color, too).
Inner fenders were black on both sides (semigloss?).
My guess is that bedsides were body color, even behind fenders.
Tim
#104386 07/18/2003 1:41 AM
Anonymous
Unregistered
Anonymous
Unregistered
I think the semi gloss black was the primer. The NOS parts I have seen are the same color perhaps they where dipped in primer and sprayed body color.
#104387 07/18/2003 2:51 AM
Metalman,
What was the primer that was used? It is hard as h*** to get off.
Tim
#104388 07/18/2003 2:56 AM
Thanks for the info! I'll go with the semi-gloss, it will be alot easier anyway. mh
#104389 07/18/2003 11:49 AM
Anonymous
Unregistered
Anonymous
Unregistered
I do not know but I do not think it comes close to the quality of what we have today. I think the parts where dipped because a lot of the nos parts have runs. They might have done a little sanding as needed on the exterior and sprayed body color. A low gloss black looks close. It is by no means flat. Ray
#104390 07/18/2003 8:47 PM
Anonymous
Unregistered
Anonymous
Unregistered
Is it possible that they could vary from plant to plant / month to month / supplier to supplier?
My first '49 had very glossy inner fenders. I ended up stripping and painting with gloss black Centari paint. When people would look under the hood the responses would always vary from "hey, someone got it right" to "that looks dumb - they were never that glossy" :rolleyes:
